1999 Ford Taurus battery dead after parking overnight
PUGGIE309
  • 1999 FORD TAURUS
  • 6 CYL
  • FWD
  • 125,000 MILES
After leaving car over night, battery dead. Also when jumped start car will not idle
Do you
have the same problem?
Monday, April 12th, 2010 AT 9:02 AM
BMRFIXIT
  • EXPERT
PCM will need to run drive cycle before idle can be corrected in most cases when battery disconnected
Check for light in trunk
Check interior light
Check battery and have it tested as it may be a bad cell
Do a battery drain test
Monday, April 12th, 2010 AT 11:46 AM
BMRFIXIT
  • EXPERT
If no idle problem prior to the battery issue
And driving it didn't correct the idle
Throttle body and IAC valve need to be cleaned
Monday, April 12th, 2010 AT 11:48 AM
Recommended Guides
