1999 Ford Taurus A lot of problems at once.
KELLIEB
  • 1999 FORD TAURUS
  • 6 CYL
  • FWD
  • 125,000 MILES
Today I was sitting in my car for about 10 minutes while it was running and in park and the radio(after market) went out. The A/C was running and when I started to drive it was running rough so I turned the A/C off and it was a little better. Then the speedometer and the rpm gauge stopped working and would come on randomly for a minute, the airbag light came on, the wipers came on and the power windows won't go up, the headlights will not turn on. The alternator was replaced about 6 months ago.
Do you
have the same problem?
Monday, June 29th, 2009 AT 4:57 PM
BMRFIXIT
  • EXPERT
Suspect bad alternator
check fuses
good luck
Monday, June 29th, 2009 AT 6:28 PM
Recommended Guides
