1999 Ford Taurus
SCHUMACHER69
  • 1999 FORD TAURUS
  • 6 CYL
  • FWD
  • 118,000 MILES
I just finished replacing head gasket on this car. The car will not start, all it does is backfire through the intake. I have checked all electrical connections. Cold compression is 125.126.130.150.90.120. I also made sure rockers are tightened at TDC for each cylinder. I have fuel pressure and spark. Suggestions are welcome. Thanks
Do you
have the same problem?
Tuesday, May 18th, 2010 AT 10:06 PM
BMRFIXIT
  • EXPERT
Check wires and firing order
Wednesday, May 19th, 2010 AT 6:10 AM
Recommended Guides
