1998 Ford Taurus transmission trouble
BEASTA29
  • 1998 FORD TAURUS
  • 6 CYL
  • 148,000 MILES
I wanted to know how do I take out a transmission in a 1998 ford taurus and is it easy to replace it?
Do you
have the same problem?
Monday, August 18th, 2008 AT 10:38 PM
  • EXPERT
Hi there,
it is not that hard to remove, but you will have to know what you are doing, and make sure that you have all the correct tools, you have to remove the drive shafts, so you must be able to undo the drive shaft lock nuts, I suggest that you get a manual and have a good read first then see if you feel up to doing this job.
Mark (mhpautos)
Tuesday, August 19th, 2008 AT 1:50 AM
Recommended Guides
