1998 Ford Taurus spark plugs not all firing
DTIMMONS
  • 1998 FORD TAURUS
Engine Performance problem
1998 Ford Taurus 6 cyl Front Wheel Drive Automatic
plugs 2 and 5 aren't firing, motor running sluggish, missing out
Do you
have the same problem?
Monday, March 15th, 2010 AT 11:37 PM
Engine running rough or misfiring can be cause by the following-inspect and test all the following listed below:
1. Defective spark plug.
2. Inadequate spark/coil, defective spark plug wire.
3. Lack of compression
4. False air leakage.
5. Faulty fuel injectors.
6. Insufficient fuel pressure.
7. Contaminated fuel.
8. EGR valve that is leaking.
9. Oxygen sensors.
10. Throttle position sensor.
Monday, March 15th, 2010 AT 11:51 PM
Recommended Guides
