1998 Ford Taurus overheating
APERRADO
  • 1998 FORD TAURUS
Engine Cooling problem
1998 Ford Taurus 6 cyl Two Wheel Drive Automatic 250.00 miles
my ford overheating when I drive in town I changed the thermostat and the problem still
Do you
have the same problem?
Sunday, April 13th, 2008 AT 10:55 PM
  • EXPERT
Hi there,
Have the cooling system pressure tested for external leaks, also check the pressure cap. Have the radiator cleaned & flow tested, make sure any cooling fans are working correctly, Ensure the system is bleed of air and if still the problem persists have a head check done to determine if you have a head gasket issue.
Mark (mhpautos)
Monday, April 14th, 2008 AT 6:48 AM
Recommended Guides
