1996 Ford Taurus won't run
HERMANOW
  • 1996 FORD TAURUS
  • 6 CYL
  • FWD
  • 112,000 MILES
I had the car out of service for about a month. When I tried to start it, the battery had gone bad. I replaced the battery, and now the car starts and a couple of seconds later shuts down. I tried disconnecting the battery for a few minutes and then connecting and restarting. But it continues to start and then shut itself back off.
Do you
have the same problem?
Tuesday, July 27th, 2010 AT 1:35 PM
Disconnecting the battery causes the computer to lose it memories it probably needs to relearn its idle speed
Tuesday, July 27th, 2010 AT 1:48 PM
HERMANOW
This one has had a dozen opportunities to learn how to idle. It starts right up, then shuts right down within 2 seconds. If I gas it, it will rev up, but still shut down within 2 seconds.
Tuesday, July 27th, 2010 AT 2:19 PM
Inspect and test the idle air control valve, EGR valve, MAF and TPS sensors-to include the fuel pressure
Tuesday, July 27th, 2010 AT 4:43 PM
Recommended Guides
