1996 Ford Taurus not starting
ANUNEZVEGA
  • 1996 FORD TAURUS
  • 6 CYL
  • 123,000 MILES
Auto was stuck in the snow. It was taken out. Engine would not turn on. Has new starter, antifreeze was checked and filled. I had to jump the car once. The battery was dead. Could not turn on the car for 4 days. Finally got it to the mechanic. Needed a new battery, but now I am told that there is antifreeze mixed with the oil. Is there anything that I can use to eliminate it. The antifreeze.
Do you
have the same problem?
Monday, January 4th, 2010 AT 2:30 PM
BMRFIXIT
  • EXPERT
Coolant in with the oil
its a headgasket failure
Monday, January 4th, 2010 AT 9:05 PM
Recommended Guides
