1995 Mercury Sable Sedan- overheating or normal?
H_SARIA
  • 1995 FORD TAURUS
I bought a used 95' mercury sable which is exactly same as ford taurus. It runs good. Everything if fine. Has 125 k miles on it. One question the engine starts at cold temp(the engine temp. Gauge is at cold and then goes up to the highest point of normal- to the point it says 'N' and mostly remains at the same. Is that normal or some problem. Do I have to change the engine oil or anything? Any suggestions
Do you
have the same problem?
Wednesday, February 14th, 2007 AT 11:56 PM
KNIGHTRIDERKITT2000
Replace the thermostat, thats the first thing I would do
Thursday, February 15th, 2007 AT 5:03 AM
H_SARIA
Is the thermostat expensive to get replaced?
Also the engine oil looks very dark. Could that be the reason?
Thursday, February 15th, 2007 AT 11:38 AM
KNIGHTRIDERKITT2000
Shouldnt cost much, if you do it yourself it should be around $15 for thermostat and gasket, if the oil is that dirty change it and the filter.
Thursday, February 15th, 2007 AT 4:17 PM
H_SARIA
Thanks for the information.I will get it checked and get it changed.
Thursday, February 15th, 2007 AT 4:54 PM
Recommended Guides
