1995 Ford Taurus Erratic Engine Temperature 1995 Ford Tauru
JOE YIP
  • 1995 FORD TAURUS
  • 6 CYL
  • 51,600 MILES
Car mileage is original and equipped with automatic temperature control. Engine temperature gauage fluctuates erratically when you drive reaching hot at times. Engine electric fan is working and coolant level is normal. Not sure if guage is broken or not. I have replaced thermostat, radiator and coolant and symtoms persists. I am guessing some sensor is malfunctionally or water pump problem (impeller broken internally and not functionally constantly).
Do you
have the same problem?
Monday, May 3rd, 2010 AT 9:03 PM
BMRFIXIT
  • EXPERT
Do a head gasket test
Tuesday, May 4th, 2010 AT 6:59 PM
Recommended Guides
