Engine coolant sensor location please
GRAFFIXX808
  • 1995 FORD TAURUS
Engine Cooling problem 6 cyl Front Wheel Drive Automatic
Where is the engine coolant temperature sensor located?
Do you
have the same problem?
Monday, January 18th, 2010 AT 8:54 PM
2CARPROS KEN
  • ADMIN
  • 11,030 POSTS
the engine coolant sensor is located at the top front of the engine. Here is a guide that will show you what you are in for when doing the job.
https://www.2carpros.com/articles/coolant-temperature-sensor-cts-replacement
Here is the location for your car (below)
Cheers, Ken
Tuesday, October 10th, 2017 AT 2:42 PM
JMGONZALEZ
  • 1999 FORD TAURUS
  • 6 CYL
  • FWD
  • 114,000 MILES
Where can I find the heating sensor on a 1999 ford taurus wagon
Tuesday, October 10th, 2017 AT 2:42 PM (Merged)
BLUELIGHTNIN6
  • EXPERT
  • 16,945 POSTS
If you are referring to the engine coolant temperature sensor than it is located on the rear of the engine block near the thermostat
GRAYFENDERBENDER
  • 2000 FORD TAURUS
2000 Ford Taurus 6 cyl Front Wheel Drive Automatic
ive got a 2000 ford taurus se 3.0 liter v6. Its overheating and ive found that the fans dont want to come on. I know that there's a heat sensor that kicks them on and im just wondering if anyone can tell me where its located exactly. Any input would be much appreciated.
BMRFIXIT
  • EXPERT
  • 19,478 POSTS
On rear of engine block, near thermostat
Recommended Guides
