1995 Ford Taurus
RNEWMYER
  • 1995 FORD TAURUS
  • 6 CYL
  • FWD
  • 180,000 MILES
It will not shift out of 2nd into drive it will only go about 30 mph it also will not keep the battery charged and it overheats
Do you
have the same problem?
Tuesday, April 13th, 2010 AT 10:08 PM
BMRFIXIT
  • EXPERT
Not shifting
Check tranny fluids
Check for codes and suspect internal tranny issue
Overheating
Check coolant and pressure check coolant system for leaks
Check thermostat and coolant fan operations
Check for codes
suspect and check headgasket
Battery draining overnight
Check and test battery
Check trunk and interior light if on after exiting the car
Check driver door switch
Perform battery drain test
Wednesday, April 14th, 2010 AT 5:14 AM
Recommended Guides
