1994 Ford Taurus Ignition
HOOTDOGG
  • 1994 FORD TAURUS
  • 6 CYL
  • 91,000 MILES
When you turn the key forward nothing happens. The battery is fully charged and all connections to it are unrestricted so it's not that. The gear shifter is definitely in park so its not that either(even tried starting in neutral), but nothing happens. I don't believe it's the starter itself. Has to be some type of control module or something, but which one and where would it be located.
Do you
have the same problem?
Saturday, August 15th, 2009 AT 11:02 AM
BMRFIXIT
  • EXPERT
Check and suspect starter and or starter solenoid
Monday, August 17th, 2009 AT 5:58 AM
Recommended Guides
