Car wont start
BLACKOP555
  • EXPERT
Sounds like its the fuel pump to me! Performa fuel pressure test to be sure. If its low then you should suspect fuel related, for that you should check for voltage at the pump, if thers voltage and no pump response then the pump is bad, if theres no voltage suspect inertia switch, wiring issue.
Thursday, March 16th, 2017 AT 12:42 PM (Merged)
BRIANSANTLY
  • 1994 FORD TAURUS
Computer problem
1994 Ford Taurus 6 cyl Front Wheel Drive 163000 miles
Hi guys. I have a 94 ford taurus, will not start, tries sometimes, I have spark, I have injector pulse I have fuel. Fuel pump runs continuously. I checked all grounds. I tried to assess the computer but my snap-on solus could not get in. At wits end. Brian
2CEXPT
Check the fuel pressure if its within specs
BRIANSANTLY
Ok, Razamataz, fuel pressure is 40 psii, fuel filter clean and free, repaired ground at double ground wire going to black relay box above radiator, still have spark, injector PULse and there is some fuel on plugs, just eNOUgh<
2CEXPT
Test the coolant temperature sensor and check if the injector/s and fuel pressure regulator leaking if okay clean the IACV and MAF sensor
CODIE105
  • 1994 FORD TAURUS
  • 200,000 MILES
1994 Ford Taurus is getting fuel and spark. Thought it could of been the fuel pump I changed the fuel pump, fuel filter, ccrm, and fuel pressure regulator. And the car will still not run any help?
Just don't get it
  • EXPERT
You could have good fuel pressure and not be getting fuel into the engine. Check to see if the injectors are getting power.
CODIE105
Well i'm sorry I have checked all that were for sure getting power to the injectors its very strange if we let the car sit there with the key on but not starting it and wait till the fuel pump shuts off it will start put the fuel pump will just run and run for awhile along with the cooling fan
  • EXPERT
Does the vehicle have a factory security system?
SAMUELJ21
  • 1994 FORD TAURUS
Engine Performance problem
1994 Ford Taurus 6 cyl Front Wheel Drive Automatic
I hav just installed new timing belt. It has been sitting for a few years and wondered if the fuel pump may be oxidized and gummed up and cannot get fuel to injectors? I know there is spark forsure.
Thursday, March 16th, 2017 AT 12:43 PM (Merged)
2CEXPT
The only way to tell is to check the fuel pressure to rule out the fuel filter, intank pick-up sock and the fuel pump
SAMUELJ21
There is no fuel pressure.
2CEXPT
Fuel pump coming On and no fuel pressure its defective
BOB HANRIGHT
  • 1994 FORD TAURUS
  • 6 CYL
  • FWD
  • 260,000 MILES
1994 Ford Taurus Wagon 3.0L engine. Car starts and stalls every once and awhile and then just turns over without starting. Changed the fuel filter and the distributor/rotor still happens. I noticed after changing the fuel filter, that when I disconnect the negative terminal wait a couple of minutes and reconnect it. The car returns to normal and starts rightup. Any Ideas?
PAUL6691
I've had similiar problems on another type of car and it was the crank sensor
2CEXPT
When it stalls don't wait- do below immediately to determine if its a fuel or spark issue
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, Do you hear the fuel pump come On when you turn key on? If not check fuel pump fuse and fuel pump relay if okay-check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
FIXITMR
  • EXPERT
You could try getting codes read but you may be erasing them when you take cable off.
KCROUCH17
  • 1994 FORD TAURUS
  • 6 CYL
  • FWD
  • 156,000 MILES
Electrical problem
1994 Ford Taurus 6 cyl Front Wheel Drive Automatic 156000 miles
Sometimes my car will run great for a couple of weeks, then it will crank over very strong but won't start. I have had it at my mechanic, but unless he can duplicate the problem, he can't find anything wrong. The A/C is not working, the back doors and windows can't be opened from inside the car. I can't afford to take it to Ford, but they charge way to much. Please help.
BLACKOP555
  • EXPERT
Im in the same position as your mechanic, sorry.
I cant help you diagnoss this unless you can find out if its not getting fuel to the engine or spark/ignition when the vehicle wont start.
KCROUCH17
I am getting fuel, an I am getting a spark. I was told it might be the CCRM or PCM?
