1993 Ford Taurus stalling problem
DAN.FELDER
  • 1993 FORD TAURUS
  • 6 CYL
  • FWD
  • 38,000 MILES
My car starts right up, driving at 50-55 no problem, come to a stop light, and no power, the more I hit the gas, the quicker it stalls, then have to pull over and restart, the longer I wait the longer I can drive, temp is normal, if I stomp on the gas after sitting at light it backfires and die's. Sometimes I have to shut the motor off to restart, most times it stalls. What could be causing this. Also how do I read the codes on a 93 tarus without the scanner?
Do you
have the same problem?
Monday, March 16th, 2009 AT 6:17 AM
BMRFIXIT
  • EXPERT
Check fuel pressure
suspect TPS
Monday, March 16th, 2009 AT 6:30 AM
Recommended Guides
