1993 Ford Taurus only 2.8 volts at fuel pump inertia switch
GJO69
  • 1993 FORD TAURUS
  • 6 CYL
  • FWD
  • 10,000 MILES
I replaced faulty ignition starter switch (worked but had excessive drag and binding). Also found low voltage at fuel pump inertia switch (2.8 volts). Jiggled wires at ign. Starter switch and they rose high enough to run pump, but not any more. Wiring/contacts/plugs look perfect. Engine cranks great. All the bells and whistles work except pump and I know it's good. Please help it's my mother-in-law's car and I'm tired of working on it. I would love to donate but I'm maxxed out on my cards.
Do you
have the same problem?
Tuesday, July 28th, 2009 AT 3:57 PM
Check the ignition switch and fuel pump relay
Tuesday, July 28th, 2009 AT 4:03 PM
GJO69
Where and how do you check it? These books now-a-days leave out way too much
Tuesday, July 28th, 2009 AT 4:07 PM
Get your ignition switch tested if you have to do this for the fuel pump to come on.
Tuesday, July 28th, 2009 AT 4:52 PM
Recommended Guides
