1993 Ford Taurus 1993 Ford SHO Taurus, WONT RUN
ELDAWGFATHER
  • 1993 FORD TAURUS
  • 6 CYL
  • FWD
  • MANUAL
  • 185,345 MILES
HELLO MY 1993 TAURUS SHO WONT START, THE TIMEING BELT IS GOOD, IT GETS SPARK AND FUEL. IT WILL TURN OVER BUT WILL KINDA SOUND LIKE THE TIMING IS OFF, THEN I PULLED THE INTACK PIPE OFF THE RIGHT SIDE, THE PIPE THAT HAS THE MID ON IT AND IT STARTED UP AND BACK FIRED AND RPMS WENT UP THEN IT DIED AGAIN. WHAT DO YOU THINK COULD BE THE PROBLEM. ALSO WERE IS THE DIONOSTIC PLUG IN ON THIS CAR
Do you
have the same problem?
Monday, November 1st, 2010 AT 9:50 PM
  • EXPERT
Will it start with starting fluid?
Tuesday, November 2nd, 2010 AT 7:54 AM
Recommended Guides
