1992 Ford Taurus Heater Core
WORKER_1
  • 1992 FORD TAURUS
  • 6 CYL
  • 154,000 MILES
They told me that my car needed a heater core and I wanted to know were it is located.
Do you
have the same problem?
Monday, February 11th, 2008 AT 9:23 PM
ED ARMES
It is located under the dash board. Requires removing alot of stuff to get at. If it is not leaking, you may be able to remove the hoses and use a garden hose to back flush the core. Do this by alternating back and forth between orfices til it runs free and clear. If it is plugged, could be the water pump impellor has failed, ( typical on 3.0 engine ). No coolant flow allows sediment to seal heater core shut.
Monday, February 18th, 2008 AT 5:04 PM
Recommended Guides
