1992 Ford Taurus
JANELLLE_JORDAN
  • 1992 FORD TAURUS
Engine Cooling problem
1992 Ford Taurus
What causes rusty goop in radiator.
Do you
have the same problem?
Thursday, May 14th, 2009 AT 10:44 PM
JGAROFALO
Coolant should be drained and replaced periodically. Otherwise, the corrosion resistance of the coolant "wears out" and corrosion occurs. You need to drain, flush, and refill your cooling system with fresh antifreeze.
Saturday, May 16th, 2009 AT 6:27 AM
Recommended Guides
