1973 Ford Taurus 1973 Ford Taurus has no Headlights
GALEDIXIE
  • 1973 FORD TAURUS
  • 6 CYL
  • 12,500 MILES
The Ford Taurus has paarking lights when you turn the switch on. Put when you turn he switch on head lights, they do not come on. I have changed the switch, the turn signal piece, and put new bulbs in. The headlights will come on when I pull the turn signal toward me. They appear to be in brights. But when I push the turn signal away from me, no headlights appear. I have also checked all fuses. Is there anything else that could cause this problem to your knowledge?
Do you
have the same problem?
Saturday, May 22nd, 2010 AT 9:24 PM
73 wow! Try checking the dimmer switch
Saturday, May 22nd, 2010 AT 9:31 PM
Recommended Guides
