Check engine light is on?
DWAYNE JOHNSON
  • 2008 FORD RANGER
  • 75,000 MILES
Car stalled seemed like was out of fuel but restarted now check engine light is on
Monday, March 25th, 2013 AT 10:57 AM
  • 52,797 POSTS
Get the code. could be fuel pump but maybe the idle air control.
Check out his CAN scan video
https://youtu.be/InIlnsjOVFA
the code will give us a direction
Monday, March 25th, 2013 AT 11:22 AM
DWAYNE JOHNSON
Was driving at the time not idleing just died then took about 30 seconds of winding over to restart
Monday, March 25th, 2013 AT 11:31 AM
  • 52,797 POSTS
Ok, still need the code and the fuel pressure needs to be checked.
Monday, March 25th, 2013 AT 11:42 AM
ANASR
  • 2008 FORD RANGER
Computer problem
2008 Ford Ranger 6 cyl Two Wheel Drive Automatic
I have a question about a 2008 Ford Ranger. Before buying a scan tool for it, I would like to know if this model operates in CAN protocol as per the standard for all 2008 vehicles and newer, or is it still operating the OBD-II protocol?
Thanks,
Amr Nasr
Friday, November 27th, 2020 AT 9:44 AM (Merged)
DAVE H
  • 13,383 POSTS
Most new vehicles and most good scantools are CAN capable !
The Diagnostic Methods Section provides information on routine diagnostic tasks.
When following powertrain diagnostics on vehicles with on board diagnostics (OBD), the system may be checked by an off-board tester referred to as a scan tool. This part contains information for carrying out diagnostics with a scan tool. A scan tool has certain generic capabilities that are standard across the automotive industry in the United States and Canada. All functions are selected from a menu. Refer to the instruction article provided by the tool manufacturer.
High Speed Controller Area Network (CAN)
High speed CAN is a serial communication language protocol used to transfer messages (signals) between electronic modules or nodes. Two or more signals can be sent over one CAN communications network circuit allowing 2 or more electronic modules or nodes to communicate with each other. This communication or multiplexing network operates at 500kB/sec (kilobytes per second) and allows the electronic modules to share their information messages.
Included in these messages is diagnostic data that is outputted over the CAN + and CAN - lines to the DLC. PCM connection to the DLC is typically done with a 2-wire, twisted pair cable used for the network interconnection. The diagnostic data such as self-test or PIDs can be accessed with a scan tool. For additional information on scan tool equipment, refer to DIAGNOSTIC METHODS.
SANDMAN
  • 2007 FORD RANGER
  • 4 CYL
  • 4WD
  • MANUAL
  • 87,000 MILES
I have a 2007 ford ranger 4x4 turbo desiel the aircon only works for about and hour then switches off, ive takin it to ford and they replaced the the cars computer and regased it but it still does it? And the engine light comes on
Friday, November 27th, 2020 AT 9:45 AM (Merged)
Check engine light on
https://www.2carpros.com/articles/service-engine-soon-or-check-engine-light-on-or-flashing
Have the computer scanned for code/s-you have a problem within the engine management system that caused the CEL to turn on-This is your starting point of diagnosis,finding out what's going on.
CALLINECTES
  • 2006 FORD RANGER
  • 6 CYL
  • 4WD
  • 85,000 MILES
Hi Have a problem, My 2006 ranger seems to be having a fuel? Problem? It runs fine on initial startup, however after it is warmed up I lose power when I am idling for a long period(>60sec) of time or if I am coasting at highway speeds, The check engine light flashes on and off and I lose power, If I give it gas it kicks back in evetually, Or if I hold the idle up the problem does not occur. Could this be a fuel pump going bad? I went ahead and replaced the plugs, wires, checked the ignition coil and changed the fuel filter to no aviale. Is thier another sensor that could be causing the problem, Thanks Chris
Friday, November 27th, 2020 AT 9:46 AM (Merged)
Have the computer scanned for code/s-you have a problem within the engine management system that caused the CEL to turn on-This is your starting point of diagnosis, finding out what's going on.
CALLINECTES
Codes found P0171, P0300, P0303, P0304, PO305, P0316, I also tested fuel pressure seems low 62psi. I appreciate the help I will definitely "donate" as soon as my paypal clears. Chris
P0171
1. Vacuum leaks
2. EGR and PCV valve.
3. Low fuel pressure.
4. Dirty fuel injectors.
5. Mass Air Flow Sensor.
Misfire codes
1. Defective spark plug.
2. Inadequate spark/coil, defective spark plug wire.
3. Lack of compression
4. False air leakage.
5. Faulty fuel injectors.
6. Insufficient fuel pressure.
7. Contaminated fuel.
8. EGR valve that is leaking.
9. Oxygen sensors.
CALLINECTES
So I have two matching things, three if you count the pressure test, Low fuel pressure, I guess either I have garbage in my gas tank or my fuel pump is going bad?
WANDER_AMERICA
  • 2006 FORD RANGER
  • 6 CYL
  • 4WD
  • 31,000 MILES
The check engine light came on at exactly 31,000 miles. No weird noises, no knocking, fluids look good, no weird smells, runs fine. Is it a factory installed "warning" that it's time for a visit to the dealer? A tune-up? How do I get the light to turn off. I live in a remote area of Alaska with no dealer support. Thanks!
Friday, November 27th, 2020 AT 9:49 AM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
Check engine light means there is a trouble code(s) that has been stored in the vehicle's computer system. You need to retrieve the trouble code(s). Most auto part stores will do this for your for free, or you can purchase a diagnostic scanner and do it yourself. Post the code(s) you get and we can further assist you with the problem.
LBARAK
  • 2005 FORD RANGER
  • 6 CYL
  • 38,000 MILES
My 2005 Ford Ranger's engine light came on yesterday. It's a V6, 3 liter. Belts look OK, due for an oil change. When idling getting slight chugging. Does it need a new fuel filter?
DAVE H
  • 13,383 POSTS
Take the vehicle to a good autoparts store (autozone etc.) have them scan the computer(PCM) for codes (most do this free) .. repost with the codes for a better diagnosis and repair advice ..
https://www.2carpros.com/forum/automotive_pictures/266999_AAA2_7.png
SHULTZR52
  • 2005 FORD RANGER
  • 190,000 MILES
My check engine light is on. I checked all fluids and its still on. I can still drive it. What can trigger my light? I am gonna try to re[pair the problem myself so the more detail u can provide the better. The light came on while I was driving, I don't know if that makes a difference.
TY ANDERSON
  • 684 POSTS
You'll need to have the vehicles' computer scanned for fault codes so I can assist you better. Most retail auto parts suppliers will scan for free. Find out what the code is and get back to me. TY
ANNPRIDE
  • 2005 FORD RANGER
  • 6 CYL
  • 87,000 MILES
How can I get my engine light off, I just had the fuel pump replaced on 2005 FORD ranger
Friday, November 27th, 2020 AT 9:50 AM (Merged)
WRENCHTECH
  • 20,757 POSTS
The only way your going to get it off is to resolve the issue that put it on in the first place. You can go to Autozone and they will clear the computer but if the problem is not satisfactorily resolved, it will just come back on again.
