2006 Ford Ranger Clutch problem, unable to shift/ soft peda
STEPHANIE48649
  • 2006 FORD RANGER
  • 6 CYL
  • 4WD
  • MANUAL
  • 144,000 MILES
The last couple of days it's been in the negative digits. The truck has only acted up once before. We let it warm up a little longer and the clutch was fine. It was spongy, but not going into gear. We've thawed the truck out to see if it would shift into gear, no luck. We tried to bleed the line out, and it made the clutch worse, like there is nothing at all there. Can you help us?
Do you
have the same problem?
Saturday, January 17th, 2009 AT 9:43 AM
BMRFIXIT
  • EXPERT
Suspect bad clutch master or slave cylinder
Saturday, January 17th, 2009 AT 1:17 PM
Recommended Guides
