2004 Ford Ranger
JEREMIAH1937
  • 2004 FORD RANGER
  • 6 CYL
  • 92,000 MILES
Just put a new battery in and it still won't crank. Interstate said the charging system was good. It WILL start when I jump it though. All I hear befoer I jump it is a faint "click" but it doesn't turn over.
Do you
have the same problem?
Friday, January 8th, 2010 AT 5:55 PM
  • EXPERT
This may sound elementary, but make sure the battery terminals are clean and tight. Also, check the ground to the engine block to make sure it is clean and tight too.
Finally, if everything is good, check the wiring from the alt to the battery. There is a fuseable link there which may be bad. Check if for continunity.
Let me know what you find.
Tuesday, January 12th, 2010 AT 9:42 AM
Recommended Guides
