2003 Ford Ranger problem with not engaging into gear when t
JUSTINOLSON
  • 2003 FORD RANGER
  • 6 CYL
  • MANUAL
  • 96,000 MILES
I have been told by a few people that they think it is the pump on the clutch. Any thoughts
Do you
have the same problem?
Monday, February 22nd, 2010 AT 5:41 AM
  • EXPERT
Hi there,
These modern transmissions are extremely complex and guess work does not factor in any diagnosis, you should first have a scan done to check for any transmission related fault codes, and the trans should be assessed by a trans specialist as there are a number of mechanical tests that also can be done to help find the exact cause of this problem.
Mark (mhpautos)
Monday, February 22nd, 2010 AT 6:22 AM
Recommended Guides
