2003 Ford Ranger
RON MILLER
  • 2003 FORD RANGER
  • 6 CYL
  • 4WD
  • MANUAL
  • 52,000 MILES
Recently my ranger just stopped running with no indication of any problems. Had it scanned and all the technician would tell me, was that the fuel pump was bad. I changed the fuel pump, changed the filter and still won't start. I have probed the the electrical connection, no power showed. The fuse is good and the relay for the pump appears to work properly. There is fuel in the injector manifold but no pressure. Could use some help. Thanks
Do you
have the same problem?
Friday, January 2nd, 2009 AT 10:49 PM
DAVE H
Hello and thanks for the donation.
Have you checked the Inertia Fuel Shut-Off Switch. In right kick panel. (Underdash). Try resetting the switch by pressing the button
Friday, January 2nd, 2009 AT 10:58 PM
RON MILLER
Thanks, the switch was it.
Saturday, January 3rd, 2009 AT 8:03 AM
Recommended Guides
