2002 Ford Ranger won't start
RONTWOHAWKS
  • 2002 FORD RANGER
Electrical problem
2002 Ford Ranger 6 cyl Four Wheel Drive Manual
I went to start the truck after moving it to the back yard. When I went to move again it wouldn't start. Replaced the starter relay switch, no change. Have accessories when turning the key back but turn to start it and everything dies. Ignition switch? If so, how hard to change?
Do you
have the same problem?
Tuesday, January 26th, 2010 AT 11:00 AM
  • EXPERT
Chances are the starter is the problem. Try this. Have a helper turn the key to the start position while you check for power to the smaller wire on the starter. You should get 12+ volts to it. Check that and let me know what you find. Also, before doing that, make sure the battery terminals are clean and tight and the battery is good.
Let me know what you find.
Tuesday, February 2nd, 2010 AT 9:41 PM
Recommended Guides
