2002 Ford Ranger 2002 Ford Ranger STARTING PROBLEM
DCAMPMI
  • 2002 FORD RANGER
  • 6 CYL
  • 123,000 MILES
Ford Ranger is taking longer cranking time to start.
Changed plugs and plug wires last year.
Just changed fuel filter and air filter.
If I turn the key to the run position for about 10 seconds and do that 2 or 3 time and then turn the key to start the truck starts right up.
Not sure if it's a fuel pump issue or not.
When truck starts it drives fine. When engine is hot the truck starts on first crank. When it cools off then the cranking problem starts.
What do I look at next.
Do you
have the same problem?
Saturday, April 17th, 2010 AT 9:50 PM
BMRFIXIT
  • EXPERT
Check fuel pressure also do an injector leak test
Sunday, April 18th, 2010 AT 9:32 PM
Recommended Guides
