What causes the severe engine vibration at idle to low revs
GRAHAMCONNEAR
MEMBER
2009 FORD RANGER
100,000 MILES
The vehicle is a 2.5 litre diesel, turbo engine. When driven at normal revs the vibration seems to go.
Monday, November 7th, 2011 AT 6:22 PM
MECHANIC
Check motor mounts and trans mounts. Often the rubber mounts wear and then you feel the engine vibration.
SPONSORED LINKS
Monday, November 7th, 2011 AT 6:24 PM
KIM227
MEMBER
2004 FORD RANGER
6 CYL
2WD
AUTOMATIC
113,000 MILES
I have a bad vibration starting around 60 and up in the right front. The tires were balanced, tires rotated, wheels changed, then tires replaced. Bearing were checked, everything is tight and within toloerance. Universal joints replaced, etc.
Cannot seem to figure out what the problem is
Saturday, August 3rd, 2019 AT 12:59 PM
(Merged)
RACEFAN966
MECHANIC
Have you checked the ball joints and tie rod ends?
(Merged)
KIM227
MEMBER
Yes all of that has been gone over and the mechanics can't find anything out of the odinary.
(Merged)
RACEFAN966
MECHANIC
Has the right front tire been checked for a defect? It may have a factory defect where the tire is seperating and just hasn't been noticed. It is worth asking them to check for.
SPONSORED LINKS
(Merged)
HAWAIIANCALVARY
MEMBER
2004 FORD RANGER
6 CYL
4WD
AUTOMATIC
89,000 MILES
2004 ford ranger 4x4 4.0 6 cyl 89000 miles. Had rear brakes done 2 wks ago. First ride out at 50-60 mph it gets a vibration or shake you feel in the seat, feels like right rear out of balance have hade tires balanced rear drums were replaced in brake job were replaced again and balanced checked all good. It still vibrate/shakes at 50-60 mph, almost constant. It fades from time to time. Any suggestions?
(Merged)
MECHANIC
This will be a problem in the rear brakes, tyres or suspension, did they replace the brake drums?
Mark (mhpautos)
(Merged)
HAWAIIANCALVARY
MEMBER
Yes they did, and have since replaced the new ones, and it still happens. Took it to another shop and they test drove it came back looked ath the shocks ujoints supsention, then checked th new drums and noted that this 2nd set were warped and needed to be replaced.
(Merged)
MECHANIC
I was suspecting this, I have come across this with other ford commercial brake drums, were they original or after market?
Mark (mhpautos)
(Merged)
PLUMBER1DV8
MEMBER
1 POST
2001 FORD RANGER
6 CYL
2WD
AUTOMATIC
78,000 MILES
Hi, I have a 2001 ford ranger 2wd 3.0 automatic. At 60mph the truck vibrates pretty bad. I put new tires on it checked the front end seems tight. Any ideas would be great. Its fine at slower speeds and seems to be fine at about 70mph but not at 60-65.
Thanks dave
Saturday, August 3rd, 2019 AT 1:00 PM
(Merged)
MECHANIC
Hi there,
This sounds like a tyre issue, check the balance and for an out of round tyre. Re check all suspension & steering, if unsure have a mechanic check this for you,
