2001 Ford Ranger Heater stops working when truck idles
SAKRANMM
  • 2001 FORD RANGER
  • 4 CYL
  • FWD
  • 131,000 MILES
When I am driving with the heat on, it works fine. But when I come to a red light for more than a few seconds, the heater temperature drops dramatically. When I start moving again, the temperature is fine.
Do you
have the same problem?
Friday, December 28th, 2007 AT 3:38 PM
MERLIN2021
  • EXPERT
Try warming the Vehicle, then carefully feel the heater hoses, are they both hot? If one is cooler than the other, You need to flush the core, or do a replacement job on the heater core. Also if the system has a heat control valve on the heater hose, make sure it is working! Also check the thermostat, and the temperature blend door, thats under the dash, in the heater plenum.
Friday, December 28th, 2007 AT 4:43 PM
Recommended Guides
