2000 Ford Ranger Won't run
BEFORDUDDLED
  • 2000 FORD RANGER
  • 6 CYL
  • 125,000 MILES
My flex fuel truck wouldn't start after a cold spell, 16 below. When it started after warming up it ran real fast then died after a minute. I changed the plugs and the same thing with starting then dying happened. I then changed the fuel filter and it started right up again but ran crappy for a moment then cleared up and ran fine but fast. After several minutes it died again. It won't start now.
Do you
have the same problem?
Saturday, January 9th, 2010 AT 3:34 PM
SERVICE WRITER
  • EXPERT
Sounds like there may be too much air coming into the engine unmetered. Is there a check engine light at all? I would look for a vacuum leak and check for codes.
I'm not sure if the fuel filter scenario is sheding light on the problem because of the symptom change,
If it is relevant, then I need to have the fuel pressure checked against spec.
Saturday, January 9th, 2010 AT 8:27 PM
Recommended Guides
