This code is telling us that one of the sensors is reading out side the normally parameter range, now depending on which sensor is at fault will determine the severity of this problem, there is no way to know until the code is read, it is not a good idea to ignore these codes as the problem may escalate into a serious issue, something like a faulty knock sensor can lead to a hole burnt in a piston if left long enough, at least have the code identified so you know what the problem is.
Mark (mhpautos)
Thursday, September 10th, 2009 AT 4:12 AM
