2000 Ford Ranger Check Engine Light
ADOBRENZ
  • 2000 FORD RANGER
  • 6 CYL
  • 4WD
  • 78,000 MILES
Ok my truck just failed California smog check because the check engine light does not function. I guess the light is burned out? Is this something that I can replace? I asked at autozone if this was a part that they could get and they told me it was a dealer specific light. Apparently there is some history of the truck that I am not aware of. I bought it used in Wyoming and then moved to California. It is the 3.0 liter V6, automatic and 4X4. Thanks for any help.
Do you
have the same problem?
Sunday, December 14th, 2008 AT 9:40 PM
BLUELIGHTNIN6
  • EXPERT
Hello
Below is info you requested.
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_49.jpg
https://www.2carpros.com/forum/automotive_pictures/261618_Noname2_18.jpg
If engine light stays on once bulb is installed, get the codes pulled and post them and I will be more than glad to help you solve the issues.
Sunday, December 14th, 2008 AT 10:01 PM
