Won't go into reverse how do I fix this
STRIVE1984
  • 2001 FORD RANGER
  • 6 CYL
  • 100,000 MILES
I have a 2001 ford ranger won't go into reverse how do I fix this problem?
Friday, January 14th, 2011 AT 4:12 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,877 POSTS
This sounds like you need to replace the reverse shift control solenoid. You will need to drop the pan to do the job here is a guide.
They say to replace all of them as a unit. Here are guide below that will show you how to do the job.
Check out the diagrams (Below)
Cheers, Ken
Friday, January 14th, 2011 AT 6:34 AM
DOCHAGERTY
  • 9,601 POSTS
Yep I replaced the shift solenoids on my truck worked perfect
Friday, January 14th, 2011 AT 2:26 PM
TOM WALSH
  • 1999 FORD RANGER
My truck will not go in reverse. It seems to be running fine in drive. I have never had a problem with the transmission before this happened two days ago. I checked the transmission fluid level cold and after running at normal operating temperature. Fluid levels were within normal levels according to the operator's manual. The fluid is not dirty and is still red. I had the transmission fluid changed about three years ago at about 90,000 miles. It was pretty dirty before it was changed. Please let me know if you can help me.
I took the truck to an auto parts store that does free diagnostic tests, but since there was no "check engine" light or any other warning lights displayed, they could not do a test. The guy at the store said since there were no warning lights, the problem might be something like a cable connection. Any ideas? I am getting tired of looking for hills so I can use gravity to go backwards.
It is a 3.0L V6. Do not know what the transmission model code is. Where would I find it? What letters or numbers would the code start with? All the forward gears work normally.
Thanks.
Tuesday, May 4th, 2021 AT 10:50 AM (Merged)
KHLOW2008
  • 41,815 POSTS
The engine capacity indicates the trans model is 4R44E.
As no diagnostic codes are present, the problem is most likely to be mechanical.
No reverse gears.
Check the following:
1. Fluid level.
2. Shift linkage.
3. Low line control pressure.
4. Filter assembly (plugged).
5. Valve body (sticking valves).
6. Incorrectly tightened valve body bolts (cross-leaks).
7. Low-reverse servo (piston seal leaking).
8. Direct and low-reverse clutch/band assemblies.
LEBLANCR
  • 1999 FORD RANGER
  • 2.5L
  • 4 CYL
  • 4WD
  • 100,000 MILES
He stopped for gas today and noticed fluid under the truck. He checked the fluids and found the transmission was not on the dipstick. He added 2 quarts which brought it to full and headed home. When he got home (a little over 2 miles) it had started slipping a little but he got it home.
He found the return line from the radiator was off (not split but off the tube. He replaced it and tightened the radiator clamp tight. It took almost 5 quarts of fluid to fill. No leaks. It will go forward, but he has no reverse. It's driven into his apartment driveway, so he can't say if it's OK forward. He's too old to push it out of the driveway.
I'm wondering if there is any possibility that it has an air bubble that needs to be bled? Or it it's probably burned something? Looking for DIY testing before he takes it somewhere. There are no real transmission specialists nearby.
Thanks in advance.
CARADIODOC
  • 33,737 POSTS
From what you have described, it is not likely something was seriously damaged. The only thing needed for reverse that is not already working is the "low/reverse" band. That is not likely to break from low fluid level. Instead, my suspicion is he checked and filled the fluid while the engine was off. That is the correct procedure for engine oil, but not for an automatic transmission. Transmission fluid will drain down and make the level appear to be really over-full when the engine is off. That is expected and normal, so if the engine was not running when the level was checked, the fluid level is still too low.
