1999 Ford Ranger third brake light
CLOS2ONE0
  • 1999 FORD RANGER
  • 6 CYL
  • MANUAL
  • 106,563 MILES
The light that goes on top of the cab. its a brake light, i replaced the the light, the brake works, but the two lights towards the side dont work.
http://www.2carpros.com/forum/automotive_pictures/294149_DSC00273_1.jpg
how do i get the side white ones to work, the have lights.
Do you
have the same problem?
Tuesday, December 30th, 2008 AT 5:32 PM
98RANGERXLT
The two side lights work off the dimmer switch push the dimmer switch all the way up until it clicks and it will turn both inside and outside lights on. To replace the bulbs take the two screws out (Dont lose them there the only thing that holds the lght on the cab) pull out turn the socket 1/4 turn counterclockwise pull bulb out put new bulb in replace socket by turning clock wise put light pack up and put screws in.
Wednesday, December 31st, 2008 AT 8:32 PM
Recommended Guides
