1999 Ford Ranger Check engine Light
MGEC90
  • 1999 FORD RANGER
  • 6 CYL
  • 84,000 MILES
Check engine light is on (sometimes it blinks). Truck has no acceleration. Foot all the way down. Acceleration does finally respond but only after a minute or so (dangerous on the highway when merging). Codes are P1131, PO301, PO302, PO303 (Autozone). Changed two O2 sensors upstream, fuel filter, air filter, DPFE sensor, Maf sensor, TPS sensor, plugs and wires.
Do you
have the same problem?
Sunday, September 21st, 2008 AT 10:06 PM
BMRFIXIT
  • EXPERT
Codes are cylinders misfiring
check coil check injectors
reset PCM what do u have for codes returning
do an exhaust back pressure test
check MAF sensor
Monday, September 22nd, 2008 AT 6:20 AM
