1998 Ford Ranger truck stalls
JOHNNYM1
  • 1998 FORD RANGER
  • 6 CYL
  • 4WD
  • MANUAL
  • 170,000 MILES
The truck starts fine runs fine for about 45 minuts one time. Then the next time the truck runs for 10 minutes then it gets to running rough and if u touch the throttle it doesent do anything. We read the codes had two. One was the egr vacume solinoid the outher was the idle air solinoid. Replaced both ran for 30 minutes took it for a ride came back cut it off started it again and it messed up again. Asked a garage he asi dit was the fuel pump put it on and it didnt fix it. And it started stalling out. Any help is greatly appriciated thanks
Do you
have the same problem?
Saturday, November 6th, 2010 AT 10:57 AM
Inspect and test the MAF and TPS sensors
Saturday, November 6th, 2010 AT 12:06 PM
Recommended Guides
