1998 Ford Ranger transmission thunk sound
JAWEILER
  • 1998 FORD RANGER
  • 6 CYL
  • 4WD
  • 13,600 MILES
I have a 98 ranger with many issues. It needs to have a new power steering rack, tie rod ends, alignment. But now I have a hugh "thunk" sound whenever I drive in slow speed. And the O/D lite keeps flickering. Is there something wrong with the OD or tranny?
thanks
Do you
have the same problem?
Sunday, March 29th, 2009 AT 3:36 PM
  • EXPERT
HI there,
I would be getting the transmission serviced & tested by a transmission specialist, there will be a few tests that will have to be done to determine the exact cause of the harsh shift, the flashing OD light is a fault code that they can read and give some indication as to where the problem is, get this done first,
Mark (mhpautos)
Sunday, March 29th, 2009 AT 5:09 PM
Recommended Guides
