Window not working
JEANI
  • 1999 FORD RANGER
  • 4.0L
  • V6
  • 4WD
  • 340,000 MILES
My drivers side window goes up and down when it feels like it. Passenger side is working fine. Can hear clucking in dash area when I click window switch down for drivers side. Just put new switch and that was not problem. Checked ground behind plastic panel next to parking brake it clean as whistle. Also, ABS light on. Replaced ABS module bearings, replaced both front hubs, wheel sensors and bearings. ABS light will not go off. Going to check rear wheel sensors. Need help with this window before I use a bigger hammer on my truck lol. Even though it high mileage my truck runs great is well taken care of and have replaced a lot of parts on it.
Do you
have the same problem?
Friday, June 16th, 2017 AT 7:29 PM
HARRY P
  • 2,293 POSTS
For the window, the next time it acts up, hold the switch in whichever direction you want to roll it and slam the door at the same time. If this causes the window to start working, then you just need a new power window motor. The brushes inside of the motor that you have are old and not always making a strong enough contact to run the motor. The jarring force of slamming the door combined with the electrical energy being applied can get it going. I have been occasionally doing it to my window for a while now.
As for the ABS system, there are a lot of things that can get the light turned on. I would suggest taking it to someone with a good scanner and get that code read, and go from there. In my area, the local Advance Auto Parts has a scanner that will pull ABS system codes.
Thursday, January 17th, 2019 AT 6:03 PM
JEANI
  • 6 POSTS
Thanks for the advice. I have auto zone near me they do not do ABS scan. I think I dealing with some want a be mechanics. I replaced my own window since. If it was easy. I can replace the motor too. Cannot be that hard on this truck. I will have to find an advanced auto see if they can test my truck. I was told there is no test for it. But my dad was mechanic I know better. Just put nice little chunk of change into truck want to fix this on down low. Lol
JEANI
  • 6 POSTS
My ABS light came on after I pulled a pop up camper. I even put new brakes on it but I did get used ABS motor. Could not afford new one.
HARRY P
  • 2,293 POSTS
If you did the window already then doing the motor itself should be a cinch for you, as you have basically done the job once. I hate to say it but you might have to take it to a dealer to get the ABS system scanned. Paying a little to get the code(s) is still better than guessing and hoping. Let us know.
JEANI
  • 6 POSTS
I will. Ugh do not like going to dealer. I am female and they think I not car smart. Been there done that lol. Think my daddy haunting my truck lol he would. Thanks again.
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,554 POSTS
Please let us know what happens, we are interested to see what it is.
Cheers, Ken
HARRY P
  • 2,293 POSTS
Yeah I hate going to the dealer too. Honestly I hate taking my car to anyone else. But sometimes I know I have swallow that pill to get the expensive scanner hooked up.
JEANI
  • 6 POSTS
Well I just went ahead and replaced the motor and regulator my window. It was more difficult then I thought it would be but got it done and works great. Still have to deal with abs light. Also had to replace my alternator. That was easy compared to window lol got alot of attention from neighbors too lol to see a gal fixin her own truck.
KEN L
  • 42,554 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Cheers, Ken
DBONDI94
  • 1999 FORD RANGER
  • 3.0L
  • 6 CYL
  • 140,000 MILES
I got this truck about a month ago, tuned her up fluid swaps, everything. I bought it with the pass. Window not working, but the drivers did. Three days after my purchase the driver window stopped working and the dome light doesn't come on either, I've installed new motors (after he king the fuses and relays, all checked good) and have installed new switches, they still refuse to work. What else could it be?
Thursday, January 2nd, 2020 AT 7:09 PM (Merged)
CARADIODOC
  • 33,699 POSTS
Start with the most common suspect. Check for broken or frayed wires between the driver's door hinges.
BRANCHY
  • 1999 FORD RANGER
  • 4.0L
  • V6
  • 117,000 MILES
Windows work itermittantly when high humidity or raining. Wipers work the same way and the interior light doesn't work also. Sometime wipers work when others won't. Yesterday wipers worked when windows and interior light wouldn't. TThis morning every thing worked fine. I have had this problem since I have had the truck, onwer before me also, Thanking you in advance,
Larry Branch
HMAC300
  • 48,601 POSTS
This may be the gem module for both wiper uses another module as well. A pro will have to scan for codes for that. Also check ground on LH kick panel, rear of LH fender, and top center of right fender apron.
OXL832
  • 8 POSTS
  • 1998 FORD RANGER
  • 6 CYL
  • 4WD
  • 112,000 MILES
My power windows stopped working all of a sudden along with the interior lights and the electronic 4x4. I`ve checked all of the fuses, and they look good. Does anybody have any ideas?
Thank You
Larry
Thursday, January 2nd, 2020 AT 7:10 PM (Merged)
CARADIODOC
  • 33,699 POSTS
Hi Larry. Welcome to the forum. Did you check fuses under the hood and inside? Since multiple circuits are affected, I would expect to find a main fuse under the hood is popped. Sometimes it's hard to see a blown fuse. A better way to check them is with a test light or inexpensive digital voltmeter. There are two tiny contacts in the plastic where you can poke the test probe of the test light or voltmeter. The ignition switch must be on when testing the fuses because that's when these circuits are powered up. Look for a fuse that only has voltage on one of the two terminals. I apologize if I'm telling you stuff you already know.
Caradiodoc
OXL832
  • 8 POSTS
Yes I have checked the fuses under the hood with a test light also, and they all have power. Any other ideas?
Thanks
Larry
CARADIODOC
  • 33,699 POSTS
Thinking about this logically, there has to be at least two different circuits involved. The windows and 4x4 system should only have power when the ignition switch is on. The interior lights will have power all the time. If you are fairly certain all of the circuits were affected at the same time, there has to be something ahead of the ignition switch that they have in common. That would be an internal connection in the fuse box or a break in the wire feeding those fuses.
Can you find the related fuses and see if there is voltage on them? I'm sending a help request to my cousin. He has a '97 Ranger and I think he has the service manuals. Being a former tv repairman, like me, he will have no problem following the wiring diagrams.
I want to apologize in advance if I take a long time to reply. My Verizon personal e-mail provider is going through some major changes, (not for the better), and they're going out of service about 20 hours per day. When you post a response, I get an automated e-mail message directing me to it. I have to watch 24 hours per day to quickly find those messages during the few hours the system is working.
Caradiodoc
OXL832
  • 8 POSTS
Now I wonder if all these circuits share a common ground. I wish I had a wiring diagragm. I`m beginning to wonder if it has comething to do with the GEM module. I`ll do some more checking tomorrow.
Thanks for the input
Larry
CARADIODOC
  • 33,699 POSTS
The GEM module is a possibility. I got a reply from my cousin. Rather than retype eveything, here's a copy / paste version of his reply:
Using manual for '97. PW---does it have p seat, p lock? If so, do they work? If so, fuse 20A #10 (under hood) ok. Power goes to relay. Relay is activated by ignition switch. From there the power goes to the switches, one touch down relay module and GEM. Interior lights--? Are we talking dash, dome, glove box, heater control, etc? #8--20A fuse--engine compartment feeds battery saver relay--that goes to #27 a 10A mini I/P fuse panel which goes to all of the interior lights. The GEM controls the battery saver relay. 4 X 4 system seems more involved--is it in 2wd or 4wd--does the transmission shift properly, including O/D? Items included in the system are--GEM. Battery saver relay, I/P fuse panel, fuse box under hood, 4wd mode switch, electric shift control module, electric shift relay, etc. The common elements to all 3 (if this is 1 problem) would seem to be 12V, ground--, GEM, battery saver module and relay, other? If this is one problem, I would start troubleshooting the lights, that would seem to be the easiest. Other than the modules, visual troubleshooting--looking for a corroded ground, wire that looks pinched, rubbed, etc. Make sure you check all of the lights--flashers, cargo, etc for more hints. Was this intermittent, or start with no warning.
JACKG304
  • 6 POSTS
  • 1994 FORD RANGER
  • 6 CYL
  • 120,000 MILES
The power window on the passenger side will not work. I have checked the switch on the drivers side & also on the passenger side with a test light & they are working. I guess that leaves only one thing it can be & that is the motor in the passenger side door. I have the panel off the door & now I am stuck. Can someone tell me how to get to the window motor to replace it?
Any help will be greatly appreciated.
Jackg304.
