1998 Ford Ranger Fuel Filter
CCLEFTY61
  • 1998 FORD RANGER
  • 6 CYL
  • 128,500 MILES
How do I get the old filter off and the new filter on?
Do you
have the same problem?
Thursday, July 16th, 2009 AT 11:59 AM
STEVEW84
If it has the metal spring clips. Get some lube and soak the hell out of it. Move the line going into the fuel filter in and out until it moves freely. You need a special too to undo the lines. Go to an autozone and rent it. Push the tool into the srping clip and pull the line out of the fuel filter. If it is that style, which I think it is. If it has never been changed then it will fight you for a little while.
Thursday, July 16th, 2009 AT 12:16 PM
Recommended Guides
