Engine is overheating in traffic?
JOHN DOSS2
  • 1999 FORD RANGER
  • 3.0L
  • V6
  • 230,000 MILES
Replaced motor, water pump, radiator, thermostat and fan clutch, still overheats
in traffic. Transmission acting up. Can it cause overheating?
Wednesday, July 4th, 2018 AT 7:00 PM
  • 52,797 POSTS
Good morning.
Wow, lots of parts replaced.
Why did you replace the motor?
Were all these parts new?
Did you do a leak down test on all the cylinders to test for a failed head gasket from overheating?
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Thursday, July 5th, 2018 AT 5:51 AM
JOHN DOSS2
Motor locked up overheating prior. Not losing water now.
Thursday, July 5th, 2018 AT 7:25 AM
JOHN DOSS2
All parts are new. Also replaced temperature sensor.
Thursday, July 5th, 2018 AT 7:28 AM
  • 52,797 POSTS
Are all the other parts new?
I still think you need to do a leak down test on the replacement motor since it overheated. It may have damaged a head gasket.
Thursday, July 5th, 2018 AT 7:30 AM
MJGGJM12
  • 6 POSTS
  • 1999 FORD RANGER
  • 6 CYL
  • 4WD
  • MANUAL
  • 199,000 MILES
The temp guage was pegged in the red so I pulled into a gas station and the engine was running real rough. I waited a while and put in coolant, the radiator was bone dry. After that the engine would not start. I figured I must have warped the head. I pulled off one of the heads today and to me it looked fine and so did the gasket. What should I be looking for on the head to see if there is damage? And when I pull off the other head tomorrow and it looks good what else should I look for that could have been damaged from the overheating.
Thank you
Wednesday, October 28th, 2020 AT 2:09 PM (Merged)
  • 31,938 POSTS
Hi there,
You will not see all the problems with the naked eye, as little as.030"will be enough to give you a problem, and you can have cracking under the valves, get the heads to a machinist to check and report, start there.
Mark (mhpautos)
LYMANUPDYKE
  • 1999 FORD RANGER
Engine Cooling problem
1999 Ford Ranger 6 cyl Two Wheel Drive Automatic
My truck is overheating. High pressure in radiator blows out to the overflow tank. Changed radiator, water pump, thermostat and radiator cap, still overheating
Could be airlock in it-try bleeding it out-I would check the head gasket as well
LYMANUPDYKE
I drained the whole system and removed the thermostat and still overheats and losing water into the overflow tank.
Water pump defective, radiator clogged-up, radiator cap seal, fan clutch-Any white smoke coming out of the exhaust?
LYMANUPDYKE
Yes white smoke comes out of the exhaust only in the morning when I first start it up. Could the heater core cause it?
The heater core if its leaking badly and coolant is not being replenish in the radiator it will cause it to overheat.
You need to have it block and pressure tested and comeback with the results
DAWNPAQUETTE
  • 1999 FORD RANGER
  • 4 CYL
  • 10,000 MILES
My truck keeps overheating and lousing antifreeze some how. I had a mackanick just take a look at it and he said my motor was gone but truck still runs
Check the thermostat if it stuck closed, radiator if its clogged up, water pump functioning if all okay -Get it block and pressure tested to rule out the headgasket cracked head or block and an intake leak.
ONERADOK
  • 18 POSTS
  • 1999 FORD RANGER
  • 6 CYL
  • 155,000 MILES
I am having trouble with my Ranger pickup overheating, occasionally. The problem originally was erratic, but recently has become fairly regular. One of the problems is I do not get to drive it regularly, may sit for weeks at a time before able to start. Now each time I start, definite signs of water in the exhaust, steam, and losing coolant, and sometimes smell it through the heater. No significant indication of water in the oil. While dissassembling the air intake manifold, noticed what looks like water at the throttle assembly. Also, there is moisture at the intake manifold where the air intake sits. Any suggestions?
Randy
Wednesday, October 28th, 2020 AT 2:10 PM (Merged)
LEGITIMATE007
  • 5,121 POSTS
Sounds to me like you have a blown head gasket. I dont need to tell you how serious this is, just that it need to be fixed asap. Any other questions let me know, and than you very much for your donation, we will be here for you whenever y ou need us.
Jody
aka
legitimate007
ICEMAN2010
  • 1998 FORD RANGER
I have a 1998 Ranger XLT 2x4 4.0 V6 with 140,000 miles. While driving at highway speeds the engine temperature gauge spikes and claims to be reading the engine as running hot. By turning on the heat inside the cab at full blast the gauge settles back to normal. An oil change is due up (i'm 500miles past the mileage) but I have a hunch that its my thermostat. Am I close or am I barking up the wrong tree?
Wednesday, October 28th, 2020 AT 2:11 PM (Merged)
MERLIN2021
  • 17,250 POSTS
What happens if you let it warm up parked? Does it overheat then? Usually if an engine overheats at highway speeds. You have a circulation problem, or a pressure problem, Have the sysem and the radiator cap pressure tested. If the system does not hold required pressure, it will overheat.
CIP G.
  • 1998 FORD RANGER
1998 Ford Ranger 6 cyl Four Wheel Drive Automatic
my truck overheated, check fluid in rad. And looks like I have oil in it
OBXAUTOMEDIC
  • 3,711 POSTS
Can you tell if it is Tranny or Engine Oil.
If tranny oil possible that tranny cooler in radiator bad and leaking.
If engine oil possible blown head gasket.
