Engine is Overheating?
BAMABOY93
  • 1997 FORD RANGER
  • 3.0L
  • V6
  • 130,000 MILES
My girlfriends truck is overheating and I can’t find the root of the problem. I have changed the thermostat and flushed the radiator and put all new coolant in. Her father had a brand new water pump put on it and “he says” they flushed the heater core before I could get my hands on it. The temperature fluctuates up and down very quickly. But there is no smoke and the oil isn’t milky and no fouled plugs so I have ruled out the head gasket. Faulty thermostat from AutoZone or air pockets stuck in the cooling system were the last thing I could think of. But I purchased the best/most costly thermostat from AutoZone and used proper coolant and it shows no evidence of a leak because I don’t see coolant on my driveway or any area I park for extended period of time and my coolant levels aren’t dropping enough to have a leak. Could a whole engine flush help? Use synthetic when filling the oil back up? The truck is very high mileage tho, only 129,000. Any help or direction would be much appreciated, thank you.
Friday, May 1st, 2020 AT 8:43 PM
  • 108,164 POSTS
Has anyone checked the coolant temperature sensor itself? It may have a bad connection or be faulty. Also, try this. When the engine is cold, remove the radiator cap and start the engine. Does coolant shoot out? Are there any air bubbles in the coolant when it is running?
Here is a link that explains how to check for a bad head gasket. It does mention the things you checked for; however there are other checks.
and
https://www.2carpros.com/articles/engine-overheating-or-running-hot
If you look at pic 1, it shows the location of the engine coolant temp sensor (ECT).
Here are directions for replacement:
___________________________________________________
1997 Ford Truck Ranger 2WD V6-3.0L VIN U
Coolant Temperature Sensor
Vehicle Powertrain Management Sensors and Switches - Powertrain Management Sensors and Switches - Computers and Control Systems Coolant Temperature Sensor/Switch (For Computer) Service and Repair Procedures Coolant Temperature Sensor
COOLANT TEMPERATURE SENSOR
Engine Coolant Temperature Sensor
See pic 2
REMOVAL
1. Disconnect battery ground cable.
NOTE: When battery voltage is removed from the Powertrain Control Module (PCM), all learned values will be cleared and reset to predetermined values. When battery voltage is restored to the PCM, the vehicle may exhibit certain driveability concerns. It will be necessary to drive the vehicle to allow the PCM to relearn values for optimum driveability and performance.
2. Partially drain cooling system.
3. Disconnect Engine Coolant Temperature (ECT) sensor electrical connector.
4. Remove ECT sensor from lower intake manifold.
INSTALLATION
1. To install, reverse the removal procedure.
2. Tighten the ECT sensor to 16-24 Nm (12-17 lb ft).
3. Refill cooling system.
Friday, May 1st, 2020 AT 9:36 PM
VANESSA DELAO
  • 1997 FORD RANGER
Engine Cooling problem
1997 Ford Ranger 6 cyl Front Wheel Drive Manual
Good day, my engine is running hot and I'm not sure what to do fisrt, second and what to look for. Please help! It was super hot and I could smell it which is what got my attention. The gauge read all the way to the top!
Wednesday, October 28th, 2020 AT 2:14 PM (Merged)
RENAUDTN
  • 636 POSTS
First make sure you have enough coolant in your overflow tank and in your radiator (engine cold). If coolant is low, add coolant. If you lose coolant rapidly in the next days/hours, you have a leak somewhere: inspect all the hoses, radiator, radiator cap (any sign of coolant around the radiator neck?), Water pump (pay particular attention to the water pump as it is a common problem), heater core area (wet passenger floor?) Etc. If no external leak is detected you may have an internal leak (check for exhaust gas in coolant, pressure test your cooling system).
If your level of coolant is fine, make sure your thermostat is working okay: with engine at normal operating temperature, grab the upper radiator hose; it should feel very hot. If it doesn't feel very hot, just kind of lukewarm, your thermostat is stuck closed and you need to replace it.
If thermostat checks out okay, let's look at your cooling fan. I don't know if your car has electrical or mechanical fan. If mechanical: check your fan clutch; if fan spins freely (engine off) with no resistance when turn by hand (wheel of fortune style) clutch is no good. If electrical, make sure your fan comes on when your car gets in the hot zone. If fan doesn't come on, check relay, motor, connections, fuse. Try to put a jumper from the battery to the fan motor; if fan doesn't come on, motor is bad. If motor comes on, you have a bad relay, or bad wire, or bad connection.
More stuff to look at:
*your cooling system could be clogged: flush the system and refill with fresh coolant.
*your serpentine belt could be loose on the pulley; check belt and tensioner.
*your exhaust could be plugged
*your bottom hose may have collapsed
Let me know if you need clarification
TM_82094
  • 1997 FORD RANGER
  • 6 CYL
  • 4WD
  • MANUAL
  • 148,388 MILES
My truck is overheating I have replaced the radiator the t stat and the heat control valve and it is still overheating what else could b the proble
Could be airlock in the system, defective water pump and blown headgasket, cracked head or block and intake leak-if it continues get it block and pressure tested
TANYA CHERIE CAIN
  • 1997 FORD RANGER
  • 2.3L
  • 4 CYL
  • 187,000 MILES
I’ve already replaced several parts everything was running fine for two days then all of a sudden truck overheated. Changed the thermostat (old one was corroded) temperature gauge hasn’t worked since. Thought it was fixed until water started coming out of hole in muffler along with white smoke. Cut it off threw my hands up. Went out later started it right up no more smoke nothing leaking from exhaust but stalls when put into gear and losses power when starting off. Engine sounds great otherwise. Help me (female trying to do it myself).
  • 108,164 POSTS
Welcome to 2CarPros.
The idea that water was coming from the exhaust in most cases is normal. Condensation can form in the exhaust and there is a weep hole on the muffler for it to exit.
Was the smoke more like steam? What I suggest is to check a couple things in particular. First, I suggest the following checks.
confirm fuel pump pressure is within the manufacturer's specs.
confirm the catalytic converter isn't plugged.
Confirm there are no diagnostic trouble codes are not stored in the computer.
Here are links that show how to perform these tests:
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Here is a quick video that shows how to scan the computer
https://youtu.be/b2IJGfImVvw
I realize most people don't own a scanner, but most parts stores will do it for free or rent or lend a scanner to you.
Last, since you mentioned the white smoke, you may want to check if there is a head gasket issue. Here is a link that explains how to test:
Try these things. I know it seems extensive, but most of these test don't take long to perform.
KARMABOMBED
  • 1996 FORD RANGER
Engine Mechanical problem
1996 Ford Ranger 4 cyl Two Wheel Drive Manual
what could cause the engine to not start when the motor has overheated? The motor will turn over and fire, and get fuel. The motor hits but doesn't start. What could it be?
BLACKOP555
  • 10,371 POSTS
Could have warped and blew out the headgasket. Without that the cylinders will not build up pressure so it willl not run. Did coolant spray out anywhere? How long was it ran on hot?
Get a compression test done and get back to me wiht the results.
REDDEVIL73
  • 1996 FORD RANGER
  • 4.0L
  • 6 CYL
  • 4WD
  • MANUAL
  • 215,000 MILES
I just replaced the transmission in this truck and all of a sudden it started over heating and codes. It brought up codes EGR valve and differential valve was bad. Replaced both those, replaced thermostat, water pump, both sensors and ended up replacing both hoses and radiator after it blew. I drove it around after all this for thirty minutes, ran fine no issues. However, the next day I jump in it and drover it for thirty miles maybe and when I got home the water started boiling, the gauge read at 3/4 hot. I am at a loss work what could be wrong now. I hooked up me scanner and it showed the coolant temperature assembly 217 degrees. But no codes, no check gauge or engine light. No water in the oil, no loss of water or oil.
Where do I go from here? Please help.
HARRY P
  • 2,293 POSTS
Is your cooling fan working?
REDDEVIL73
Replaced the fan clutch, fan.
HARRY P
  • 2,293 POSTS
Cooling system could be clogged. Water pump may not be pumping enough. Or maybe you got a dud of a thermostat (would not be the first time I have seen it).
MICHAEL WHEAT
  • 1995 FORD RANGER
  • 6.0L
  • V6
  • 4WD
  • 280,000 MILES
My truck is overheating and building up enough pressure to blow the radiator cap off. I do not know what to do. Please help.
Wednesday, October 28th, 2020 AT 2:15 PM (Merged)
SATURNTECH9
  • 30,870 POSTS
The radiator cap has actually blown the radiator cap completely off the radiator? If so have you done a radiator block test yet? That checks for exhaust gases in your cooling system from a blown head gasket.
MICHAEL WHEAT
I have no idea how to do that. And this problem just started after a buddy replaced my serpentine belt and left the wrench on the tensioner.
  • 31,938 POSTS
Go get the head check done, most mechanics can do this test while you wait, it will show up exhaust gasses in the cooling system which will indicate a head problem, unless the belt was not fitted correctly and failed the spanner on the tensioner it will not be the cause.
SPACEYTRACEY
  • 1995 FORD RANGER
  • 4 CYL
  • FWD
  • MANUAL
  • 186,000 MILES
I'm gonna explain the problem as best I can. I am completely ignorant when it comes to cars! The truck only overheats if you try to use the airconditioner or heater, if you turn either one on steam will fill the cab of the truck, the heater doesn't blow hot, the radiator seems to be holding water however I have to keep refilling the overflow tank. The two times it overheated steam came out from under the hood and it was coming from the passenger side closest to the cab of the truck. As far as having to replace water I only have to do it every five days and I drive it about 60 miles each day. I hope you can decipher and make some sense out of this because I really need some help. Thanks so much in advance!
BILLYMAC
  • 2,204 POSTS
Hi tracy. You have a bad heater core. The core is in the heater box under your dash. Coolant runs through this core and a fan blows across it and heats your cab. When they go bad they lose coolant and no heat and fill your cab with steam. This is not an awful expensive repair but parts and labor will be about 300.00 or so. I hope this helps you billymac
