Replacing the timing belt?
GILMORAM
  • 1996 FORD RANGER
  • 320 MILES
I accidentally move the crankshaft flag play on me crankshaft sprocket. I have a 96 ford ranger. I had to replace timing belt and now I have no power. Is it the timing or the crankshaft sensor flag plate? I meant the plate that the crankshaft sensor is looking at. I think the call it the flag. Could my timing be one tooth off. Causing loss of power. It was fine until the belt broke.
Friday, March 9th, 2012 AT 8:07 PM
  • 52,797 POSTS
Good evening,
This sounds like the timing. The belt may have moved and changed the valve timing. I attached pictures of the alignment marks for you to review. Check out the diagrams (Below).
I also attached a you tube video for you of setting up the gears so the belt is in the correct location after the tensioner is set.
https://www.youtube.com/watch?v=YTgusM6S0GM
If the belt is off at the crankshaft and the distributor and the cam are in time, the truck will lack power. You can verify by performing a compression test. If the valve timing is off, the compression will be low. It needs to be about 140-150 pounds.
The plate you refer to can only go on 1 way. It fits over a keyway on the crank so it cannot move left or tight.
NOTE: Care must be taken during timing belt installation to prevent damage to the inner timing cover.
1. If not done:
a. Loosen tensioner adjusting bolt.
b. Using Camshaft Belt Tension Adjusting Tool, pry tensioner CLOCKWISE against spring tension as far as possible.
c. Tighten adjusting bolt to hold tensioner in RELEASED position.
2. Align crankshaft so number one piston is at Top Dead Center (TDC) with crankshaft key pointing straight UP and circle on crankshaft sprocket aligned with notch in engine front cover.
3. Align triangle on camshaft sprocket with triangle on inner timing belt cover.
4. Align diamond on oil pump sprocket with diamond on inner timing belt cover.
5. Install timing belt over crankshaft sprocket. Then, proceeding COUNTER-CLOCKWISE, over oil pump sprocket and camshaft sprocket.
6. Loosen tensioner adjusting bolt allowing tensioner pulley to press against timing belt.
NOTE: When performing the following step, DO NOT ROTATE crankshaft COUNTER-CLOCKWISE as timing belt may jump a cog, putting camshaft or camshaft position sensor on oil pump out of time.
7. ROTATE crankshaft two revolutions CLOCKWISE.
8. Bring crankshaft slowly, without stopping, to number one cylinder firing position (keyway directly UP).
9. Recheck timing mark alignment. Repeat steps if timing marks are not properly aligned.
10. ROTATE tensioner assembly against belt with torque wrench up to 41-45 N.m (30-33 lb-ft) and tighten adjusting bolt.
11. Tighten adjusting bolt to 35-45 N.m (26-33 lb-ft).
12. Tighten spring pivot bolt to 40-55 N.m (30-40 lb-ft).
13. Install outer timing belt cover.
Thursday, November 12th, 2020 AT 5:58 PM
JORME1954
  • 1996 FORD RANGER
  • 4 CYL
  • MANUAL
  • 150,000 MILES
I'm starting a timing belt replacement on fairly good running truck. When I removed the timing belt cover I found line up marks on the two top gears. However when I rotate the engine the marks on the gears do not line up at the same time. More confused by the manual I bought that also gave me the impression the marks would all line up at the same time.
Monday, December 7th, 2020 AT 8:48 AM (Merged)
Position the no.1 piston on its compression stroke/TDC then line the sprockets-see below
https://www.2carpros.com/forum/automotive_pictures/12900_cam_alignment_1.jpg
DAKOTAONE
  • 1996 FORD RANGER
  • 4 CYL
  • MANUAL
  • 11,200 MILES
HELP!
I have a 1996 Ford Ranger 2.3 L and I am currently in the process of installing the timing belt as I am writing this. I understand how to line up the marks on the crank with the plastic cover/TDC, but there are to other pulleys with marks on them and then the same marks are on the plastic part mounted to the engine. Do I line up those marks/shapes with the shapes/marks on the pulleys to the plastic part mounted to the engine and then would I be good to go as long as my crank is set at/TDC? Just want to make sure before I put this all back togather and may have an any issues.
Thank you for any help out there!
Dakotaone
Monday, December 7th, 2020 AT 8:49 AM (Merged)
JNOVACK
  • 723 POSTS
There is pic of tming marks for your truck also install with torque specs.
https://www.2carpros.com/forum/automotive_pictures/52960_Untitled1_2.jpg
https://www.2carpros.com/forum/automotive_pictures/52960_Untitled_2.jpg
DAKOTAONE
So what I can see of the very small illustration is that the triangle mark on the top sprocket is to match the inner cover and the diamond mark on the lower sprocket to the right is to match the intercover cover diamond mark, is that correct?
Thanks!
Dakotaone
2CP-ARCHIVES
  • 4,542 POSTS
  • 1996 FORD RANGER
  • 20,000 MILES
I just recently changed timing belt and positioning sensor now truck bucks and code says positioning sensor is still faulty and its a new one the code says it not getting connection
HMAC300
  • 48,601 POSTS
Check connection to make sure it's in correct and tight. Make sure your timing marks are aligned as pictured. And what codes were they?
SCRUFFYOAK
  • 1995 FORD RANGER
  • 4 CYL
  • MANUAL
  • 145,000 MILES
1995 2.3L Ford Ranger. Timing belt broke, trying to repair myself, now I remember how much I hate working on vehicles in the winter.
The problem is, I cannot get the crankshaft pulley bolt out. I cannot hold the pulley, I have tried several different pry bars, pipes, tire irons, etc. To no avail. This isn't a left hand thread, is it?
Help!
DAVE H
  • 13,383 POSTS
Not left handed i'm afraid. Just stubborn. You could try warming around it a little. To expand pulley. Or impact gun?
TIMING BELT
Removal
Remove spark plugs. Ensure crankshaft is set at TDC, and camshaft sprocket timing mark and oil pump sprocket timing mark are aligned with inner cover timing marks. See Fig. 1. Remove fan guard. Remove fan shroud and position aside. Remove fan retaining screws, and remove fan and shroud. Rotate drive belt tensioner and remove belt.
Remove cooling fan and water pump pulley. Discharge A/C system (if equipped) using approved refrigerant recovery/recycling equipment. Remove A/C compressor and position aside. Remove A/C compressor mounting bracket with power steering pump attached, and position aside.
Remove timing belt outer cover retaining bolt. Release 7 cover interlocking tabs. Remove timing belt cover. Holding timing belt tensioner with Camshaft Belt Tension Adjuster (T74P-6254-A) or equivalent, loosen adjusting bolt and slowly release tension. See Fig. 2. Pry tensioner away from timing belt and tighten bolt to hold tensioner in place. Remove timing belt.
  • 31,938 POSTS
Hi there,
This will be a right handed thread, Try removing the starter and locking up the fly wheel with a suitable lever, this will lock the motor, you may need an assistant to help you, the crank shaft bolt will be extremely tight.
Mark (mhpautos)
