1994 Ford Ranger Water pump
FLIPANGEL
  • 1994 FORD RANGER
Engine Cooling problem
1994 Ford Ranger 6 cyl Two Wheel Drive Automatic
The water pump on my ranger started to leak real bad, so I bought a new water pump and rented the tool to pull it off, can you please inform me on the procedure or the steps to taking it off. Thank You Very Much
Do you
have the same problem?
Monday, May 19th, 2008 AT 12:57 PM
BMRFIXIT
  • EXPERT
Remove negative battery cable
drain coolant system
disconnect lower radiator hose and heater return hose from water pump
using clutch fan holder and fan wrench remove radiator fan and clutch assembly
http://www.2carpros.com/forum/automotive_pictures/99387_clutch_fan_1.jpg
Remove drive belt
remove alternator and bracket
remove pulley and then water pump
Tuesday, May 20th, 2008 AT 1:26 PM
Recommended Guides
