1994 Ford Ranger ABS
ASMITH11
  • 1994 FORD RANGER
  • 6 CYL
  • MANUAL
  • 97,000 MILES
WHY DO ABS LIGHT STAY ON, I GOT BRAKE AND BRAKE LIGHT IS OK. AND THE FLUID IS FULL
Do you
have the same problem?
Wednesday, May 5th, 2010 AT 7:39 PM
  • EXPERT
There must be a problem with a sensor or some other component in the ABS system. Have you had the computer scanned? If the light is on, there will be a code stored in the system identifying where the problem is coming from. I recommend having it scanned to identify where the problem is located.
Have that done and let me know what you find.
Tuesday, May 11th, 2010 AT 12:43 PM
Recommended Guides
