1993 Ford Ranger Starting problems
JOEANDLETTY
  • 1993 FORD RANGER
  • 4 CYL
  • MANUAL
  • 125,000 MILES
I have 1993 Ranger 4 cyl with 125000 miles. I hadn't started it for a while and the battery went bad. Replaced the battery, would not turn the starter. Removed and had the starter test, test showed the started was good. Replaced starter relay swith and the starter would turn the engine but it would not start. No dragging at this point. Took one spark plug out and noticed that it had no fuel on it nor did it smell like fuel. I could smell raw fuel in and around the engine after every crank. What could be my problem?
Do you
have the same problem?
Saturday, January 10th, 2009 AT 11:27 AM
RENAUDTN
Have you done a fuel pressure test?
Saturday, January 10th, 2009 AT 9:46 PM
Recommended Guides
