1993 Ford Ranger fuel gauge
BUZZDOG
  • 1993 FORD RANGER
  • 6 CYL
  • 15,000 MILES
Fuel gauge pegs past full when I turn the switch on then falls to below empty and stays. I pulled the bed and replaced the whole fuel pump. Now gauge pegs past full and stays?Tried unplugging the wireing harness from the pump and the gauge stays pegged past full, plug it back up no change. Any clues?
Do you
have the same problem?
Monday, October 5th, 2009 AT 8:29 PM
  • EXPERT
Have the body control module (BCM) tested. If it is fine, the gauge itself is bad unless somehow when replacing the pump the float got stuck in the up position.
Wednesday, October 28th, 2009 AT 8:26 AM
