1993 Ford Ranger Clutch
BRANNONM
  • 1993 FORD RANGER
  • 4 CYL
  • MANUAL
  • 137,191 MILES
I just replaced my clutch disk and pressure plate, slave cylinder, and master cylinder so of course I had to pull my shift lever out and drop my transmission. My shift lever was missing pieces in the transmission (and of course only Rangers and S10s use what I needed so it's not readily available anywhere). Anyways - after I got the clutch installed, all the cylinders installed, the transmission up and the shift lever in place I checked to make sure the shift lever would move (in case anything was out of place there). My shift lever was fine so I bled the system not fully though becuase the person helping me had to leave. I started the truck and tried to shift but it wouldn't budge into any forward gear. I tried reverse and all it did was grind. I know I still have to bleed the system more but could it potentially be anything else or is it just the bleeding? Any info would be helpful. Thanks!
Do you
have the same problem?
Friday, April 30th, 2010 AT 2:54 PM
  • EXPERT
Chances are it just needs bled.
Wednesday, May 12th, 2010 AT 7:56 AM
Recommended Guides
