Engine has stalled
REEDBONE
  • 1993 FORD RANGER
  • 60,000 MILES
I was moving across yard and it shut off by its self and I check fuel rail had no fuel so I check all the relays and fuses and the inertia switch all fine I switched relays and checked fuel pump it works
Thursday, March 29th, 2012 AT 1:31 AM
No fuel check the fuel pressure with a gauge to rule out the fuel pump-
Thursday, March 29th, 2012 AT 2:59 AM
RIVERMIKERAT
  • 6,110 POSTS
Does the pump receive power? If not, is the relay being energized? If so, you'll have to trace it.
Thursday, March 29th, 2012 AT 3:00 AM
REEDBONE
  • 75 POSTS
Ya the fuel pump work and I get no power to pump I switched relays and nth
Thursday, March 29th, 2012 AT 10:48 AM
Check the inertia switch
Thursday, March 29th, 2012 AT 12:00 PM
REEDBONE
  • 75 POSTS
Already did
Thursday, March 29th, 2012 AT 12:10 PM
WRENCHTECH
  • 20,757 POSTS
You haven't answered the questions yet.
Is the pump receiving power?
What is the fuel pressure?
Thursday, March 29th, 2012 AT 12:21 PM
RIVERMIKERAT
  • 6,110 POSTS
[qoute]Ya the fuel pump work and I get no power to pump I switched relays and nth [/quote]
I'm going to take this to mean that you've both hotwired the pump and the relay to verify that the pump works. With the key in the Run position, see if you get power to pin 86 and that pin 86 is properly grounded. IF not, find out why. Trace the wire for Pin 86 back to its source.
Thursday, March 29th, 2012 AT 7:41 PM
REEDBONE
  • 75 POSTS
Has no pressure and fuel pump harness has no power
Thursday, March 29th, 2012 AT 7:58 PM
WRENCHTECH
  • 20,757 POSTS
Jump out the relay and test for power at both sides of the Inertia switch.
Thursday, March 29th, 2012 AT 8:17 PM
REEDBONE
  • 75 POSTS
Ok should I have power on both sides?
Thursday, March 29th, 2012 AT 8:21 PM
RIVERMIKERAT
  • 6,110 POSTS
The the relay. Pins 85 and 86 energize the coil. 87 and 30 carry the power for the load. You should see continuity between 87 and 30 with the coil energized. IF the coil isn't being energized, either it's not being grounded, or it isn't getting power.
The red and dark green/yellow wires should have power when the key is on and the light blue and green should go to ground. The black/yellow wire should have constant power.
Thursday, March 29th, 2012 AT 8:23 PM
REEDBONE
  • 75 POSTS
Ok I jumped my pump from the eec and grounded it and the pump come on a runs so what does that mean
Thursday, March 29th, 2012 AT 8:37 PM
RIVERMIKERAT
  • 6,110 POSTS
It means that the pump is good. Now you need to check everything you bypassed. Including whatever wiring you bypassed.
Thursday, March 29th, 2012 AT 9:08 PM
REEDBONE
  • 75 POSTS
I found the problem but idk how to fix the relay isnt closing for the pump to come on and it has power so what tells it when to close and open
Thursday, March 29th, 2012 AT 11:04 PM
WRENCHTECH
  • 20,757 POSTS
Are you sure you are checking it properly? It only powers for 2 seconds when the key is first turned on.
Thursday, March 29th, 2012 AT 11:08 PM
REEDBONE
  • 75 POSTS
Yes. My mom turns it on while I am holding it and the other relays around it r clicking besides the fp relay
Thursday, March 29th, 2012 AT 11:14 PM
RIVERMIKERAT
  • 6,110 POSTS
Ok. SO no clicking from the relay with the key on. And power and ground to the proper pins at the proper time. You need a new relay. They're usually about 20 bucks.
Friday, March 30th, 2012 AT 12:49 AM
REEDBONE
  • 75 POSTS
I got a new one today and it was the one I was testing it is doing same thing as old one and i. Ohmed out and put on anotger relay and it works
Friday, March 30th, 2012 AT 1:03 AM
RIVERMIKERAT
  • 6,110 POSTS
Ok. Pin 85 what have you got? Pin 86? 87? 30? Let's go from there.
Friday, March 30th, 2012 AT 3:59 AM
REEDBONE
  • 75 POSTS
What woukd cause a relay to not close
Sunday, April 1st, 2012 AT 12:16 AM
