1991 Ford Ranger emergency brake
CRAZYDRIVER75
  • 1991 FORD RANGER
Brakes problem
1991 Ford Ranger 6 cyl Four Wheel Drive Manual
the emergency brake is stuck how can I get it unstuck
Do you
have the same problem?
Wednesday, December 31st, 2008 AT 8:05 PM
DAVE H
  • EXPERT
BRAKE SHOES (EXCEPT E250/350 & F250/350)
Removal
Remove wheel assembly and drum. Place a wheel cylinder clamp over ends of wheel cylinder. Disengage adjusting lever from adjusting screw by pulling backwards on lever cable. See Fig. 12.
Fig. 12: Examining Rear Brake Assemblies (Except E250/350 & F250/350)
Courtesy of FORD MOTOR CO.
Move outboard side of adjusting screw upward, and back off pivot nut as far as possible. Pull adjusting lever, cable and adjusting spring down and toward rear to unhook pivot hook from large hole in secondary shoe. DO NOT pry pivot hook from hole.
Remove adjusting spring and adjusting lever. Remove secondary shoe-to-anchor spring. Remove primary shoe-to-anchor spring. Unhook cable anchor, and remove anchor pin plate.
Remove cable guide, shoe hold-down springs, brake shoes, adjusting screw, pivot nut and socket. Remove parking brake link spring and link. Note color and position of springs for reassembly.
Disconnect parking brake cable from lever. Remove secondary shoe. Disassemble parking brake lever from shoe by removing retaining clip and spring washer.
Installation
Clean and sand brake shoe contact points on backing plate. Apply a light coating of lithium base grease to contact points. Lubricate adjusting cable eye and anchor pin area. Lubricate adjusting screw, pivot and socket. To install, reverse removal procedure.
Thursday, January 1st, 2009 AT 6:05 AM
Recommended Guides
