Ford transmission e4od
JERRY BARROW
  • FORD
1990 Ford Larite XLT 5.8 L V-8 E4OD transmission 186,000 miles. Transmission has less than 4500 miles since major overhaul, transmission drops in and out of overdrive and third gear. Have taken back very many times to get problem corrected, They keep saying that fuel pump circuit codes is causing the shifting problems. Have taken to another repair shop for problem codes in the fuel pump circuit, problem with transmission still remains. Can you give me some idea about what the problem with the transmission might be.E4OD transmissions are expensive to overhaul
Do you
have the same problem?
Thursday, December 7th, 2006 AT 2:37 AM
WYNRYPEN
Id bite the bullett and get a new one
Thursday, December 7th, 2006 AT 1:28 PM
Recommended Guides
